Enable Protocol Independent Multicasting (PIM) on a CLIP interface so that it can participate in PIM routing.
  • You must globally enable PIM.
  1. In the navigation pane, expand Configuration > IP.
  2. Select IP.
  3. Select the Circuitless IP tab.
  4. Select the required CLIP interface.
  5. Select PIM.
  6. Select Enable.
    You must enable PIM on the CLIP interface for PIM to function. The mode is indicated on this tab.
  7. Select Apply.
Circuitless PIM Field Descriptions
Use the data in the following table to use the Circuitless PIM tab.
Name
Description
Enable
Enables PIM on the CLIP interface.
Mode
Specifies the PIM mode.
